disable ripng export
disable ripng export [direct | ospfv3 | ospfv3-extern1 | ospfv3-extern2 | ospfv3-inter | ospfv3-intra | static | isis | isis-level-1| isis-level-1-external | isis-level-2| isis-level-2-external | bgp e-bgp i-bgp]
Description
Disables RIPng from redistributing routes from other routing protocols.
Syntax Description
direct Specifies directly reachable subnets from the router (only interfaces that have IP forwarding enabled are exported).
ospfv3 Specifies all OSPFv3 routes.
ospfv3-extern1 Specifies OSPFv3 external route type 1.
ospfv3-extern2 Specifies OSPFv3 external route type 2.
ospfv3-inter Specifies OSPFv3-inter area routes.
ospfv3-intra Specifies OSPFv3-intra area routes.
static Specifies user configured static routes.
isis Specifies IS-IS routes.
isis-level-1 Specifies IS-IS Level 1 routes.
isis-level-1-external Specifies IS-IS Level 1 External routes.
isis-level-2 Specifies IS-IS Level 2 routes.
isis-level-2-external Specifies IS-IS Level 2 External routes.
bgp Specifies BGP IPv6 routes
e-bgp Specifies EBGP routes.
i-bgp Specifies IBGP routes.
Default
Disabled.
Usage Guidelines
This command disables the exporting of static, direct, IS-IS, and OSPF-learned routes from the switch routing table into the RIPng domain.
The following command disables RIPng from redistributing any routes learned from OSPFv3:
disable ripng export ospfv3
Platform Availability
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.2.1 Licensing Guide document.
