unconfigure tunnel
unconfigure tunnel tunnel_name ipaddress ipv6_address_mask
Description
Unconfigures an IPv6 address/prefix route from a tunnel.
Syntax Description
tunnel_name Specifies an IPv6 tunnel.
ipv6_address_mask Specifies an IPv6 address / IPv6 prefix length.
Default
N/A.
Usage Guidelines
Use this command to unconfigure an IPv6 address/prefix route from the specified tunnel.
The following example unconfigures the 6in4 tunnel "link39" with the address 2001:db8::1111/64
unconfigure tunnel link39 2001:db8::1111/64
Platform Availability
This command is available on the platforms listed for the IPv6 interworking feature in the Switch Engine v33.2.1 Licensing Guide document.ss="- topic/ph "/>
