enable pim iproute sharing
enable pim {ipv4 | ipv6} iproute sharing
Description
Enables the PIM ECMP feature.
Syntax Description
iproute IP Route.
sharing Equal Cost Multipath Routing.
Default
Disabled.
Usage Guidelines
Use this feature to allow downstream PIM router to choose multiple ECMP path to source via hash from one of the following selections without affecting the existing unicast routing algorithm:
  • Source
  • Group
  • Source-Group
  • Source-Group-Next-Hop
This feature does load splitting, not load balancing, and operates on a per (S, G) and (*;G) basis, splitting the load onto the available equal cost paths by hashing according to the selection criteria defined by the user.
Make sure that IP route sharing is also enabled using enable iproute {ipv4| ipv6} sharing.
The following command enables the PIM ECMP feature:
enable pim ipv4 iproute sharing
This command was first available in ExtremeXOS 15.3.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.2.1 Licensing Guide document.
