configure iproute add default
configure iproute add default [gateway |ipv6Gateway | ipv6ScopedGateway] {bfd}{metric} {vr vr_name} {multicast |multicast-only |unicast |unicast-only} {vlan vlan_name}
Description
Adds a default gateway to the routing table.
Syntax Description
gateway Specifies a gateway IPv4 address.
ipv6Gateway
Specifies a VLAN gateway IPv6 address.
ipv6ScopedGateway
Specifies a scoped gateway.
bfd Enables Bidirectional Forwarding Detection (BFD) protection for the route.
Note: You must type this keyword before specifying a VLAN.
metric
Specifies a cost metric. If no metric is specified, the default of 1 is used.
vr_name
Specifies the VR or VRF to which the route is added.
Default
If no metric is specified, the default metric of 1 is used. If you do not specify a VR or VRF, the current VR context is used.
Usage Guidelines
Default routes are used when the router has no other dynamic or static route to the requested destination. A default gateway must be located on a configured IPv6 interface. Use the unicast-only or multicast-only options to specify a particular traffic type. If not specified, both unicast and multicast traffic uses the default route.
The following example configures a default route for the switch:
configure iproute add default 2001:db8::1234:5678
Support for IPv6 was added in ExtremeXOS 11.2.
Platform Availability
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.2.1 Licensing Guide document.
