configure vrrp fabric-routing
configure vrrp vlan [vlan_name | vlan_list] vrid [vridval | vrid_list] {group group_name }fabric-routing [on | off]
Description
This command configures fabric routing.
Syntax Description
group Specifies VRRP VRs information that form the group.
group_name Name of the specific VRRP group.
fabric-routing Configures fabric routing on all members of the group.
on Enables fabric routing capability.
off Disables fabric routing capability.
port_list Port list separated by a comma or –.
vlan_name
Specifies the name of a VRRP VLAN.
vlan_list VLAN list (1–4,094).
vridval
Specifies the VRID for the VRRP instance. To display the configured VRRP router instances, enter the show vrrp command.
vrid_list List of virtual router IDs (1–255).
Default
N/A
Usage Guidelines
This configuration can be present on all VRRP routers, regardless of the VRRP state of the router. Fabric routing is enabled only when the VRRP router is in backup state.
You need to configure fabric routing on all members of group when a member‘s VRID is reused in another group.
The following command turns on fabric routing capability on all VR members of the group "ExtremeNet":
configure vrrp group ExtremeNet fabric-routing on
This command was first available in ExtremeXOS 22.2.
VLAN and VR list options added in ExtremeXOS 22.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.2.1 Licensing Guide document.
