enable bgp peer-group
enable bgp peer-group peer-group-name
Description
Enables a peer group and all the neighbors of a peer group.
Syntax Description
peer-group-name Specifies a peer group.
Default
Disabled.
Usage Guidelines
You can use BGP peer groups to group together up to 200512 BGP neighbors. All neighbors within the peer group inherit the parameters of the BGP peer group. The following mandatory parameters are shared by all neighbors in a peer group:
  • source-interface
  • out-nlri-filter
  • out-aspath-filter
  • out-route-map
  • send-community
  • next-hop-self
This command applies to the current VR or VRF context.
The following command enables the BGP peer group outer and all its neighbors:
enable bgp peer-group outer
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.2.1 Licensing Guide document.
