enable vrrp vrid
enable vrrp {vlan [vlan_name | vlan_list] vrid [vridval | vrid_list}
Description
Enables a specific VRRP instance or all VRRP instances on the switch.
Syntax Description
vlan_name
Specifies the name of a VRRP VLAN.
vlan_list VLAN list (1–4,094).
vridval
Specifies the VRID for the VRRP instance to be enabled. To display the configured VRRP router instances, enter the show vrrp command.
vrid_list List of virtual router IDs (1–255).
Default
N/A.
Usage Guidelines
This enables a specific VRRP instance on the device. If you do not specify a VRRP instance, all VRRP instances on this device are enabled.
The following command enables all VRRP instances on the switch:
enable vrrp
VLAN and VR list options added in ExtremeXOS 22.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.2.1 Licensing Guide document.
