Disables poison reverse algorithm for RIPng.
| vlan-name | Specifies an IPv6 configured VLAN. |
| tunnel_name | Specifies an IPv6 tunnel. |
| all | Specifies all interfaces. |
Enabled.
Like split horizon, poison reverse is a scheme for eliminating the possibility of loops in the routed topology. In this case, a router advertises a route over the same interface that supplied the route, but the route uses a hop count of 16, defining it as unreachable.
The following command disables the split horizon with poison reverse algorithm for RIPng:
disable ripng poisonreverse
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.2.1 Licensing Guide document.
