Controllers, service platforms and access points are automatically assigned a default profile unless an AP provisioning policy has been defined that specifically assigns access points to a user defined profile. During the general configuration process, a provisioning policy can be assigned to a specific profile or a new provisioning policy can be created and applied to the profile. Adoption is the process an AP uses to discover potential adopters (Controller APs of the same model, service platforms or controllers) in the network, pick the most desirable one, establish an association and obtain its configuration.
Network Time Protocol (NTP) manages time and/or network clock synchronization within the network. NTP is a client/server implementation. Controllers, service platforms and access points (NTP clients) periodically synchronize their clock with a master clock (an NTP server). For example, a NX9500 resets its clock to 07:04:59 upon reading a time of 07:04:59 from its designated NTP server.
Additionally, if the profile is supporting an access point, the profile‘s general configuration provides an option to disable the device‘s LEDs.
To define a profile‘s general configuration:
| Area | Enter a 64 character maximum description for the selected device‘s physical deployment area. This area can be further refined by floor and floor number descriptions. |
| Floor | Enter a 32 character maximum description for the selected device‘s building floor placement. This area can be further refined by floor and floor number descriptions. |
| Floor Number | Use the spinner control to assign a numeric deployment floor number (from 1 - 4094) for this device. The default floor is 1. |
A value of 0 is allowable for an auto mode where the update interval is auto adjusted by the controller based on load information.
| Server IP | Set the IP address of each server added as a potential NTP resource. |
| Key Number | Select the number of the associated authentication peer key for the NTP resource. |
| Key | Enter a 64 character maximum key used when the autokey setting is set to false (disabled). Select the Show option to expose the actual character string comprising the key. |
| Preferred | Select this option to designate this NTP resource as a preferred NTP resource. This setting is disabled by default. |
| Select the check box to enable an autokey configuration for the NTP resource. The default setting is disabled. | |
| Version | Use the spinner control to specify the version number used by this NTP server resource. The default setting is 0. |
| Minimum Polling Interval | Use the drop-down menu to select the minimum polling interval. Once set, the NTP resource is polled no sooner then the defined interval. Options include 64, 128, 256, 512 or 1024 seconds. The default setting is 64 seconds. |
| Maximum Polling Interval | Use the drop-down menu to select the maximum polling interval. Once set, the NTP resource is polled no later then the defined interval. Options include 64, 128, 256, 512 or 1024 seconds. The default setting is 1024 seconds. |
RAID controller drive arrays are available within NX9500 and NX9600 series service platforms only. However, they can be administrated on behalf of a NX9500 and NX9600 profile by a different model service platform or controller.
