To define a dynamic routing configuration:
Review existing Interface Settings using the following:
Name |
Displays the name defined for the interface configuration. |
Type |
Displays the type of interface. |
Description |
Lists each interface's 32 character maximum description. |
Admin Status |
Displays whether Admin Status privileges have been enabled or disabled for the OSPF route's virtual interface connection. |
VLAN |
Lists the VLAN IDs set for each listed OSPF route virtual interface. |
IP Address |
Displays the IP addresses defined as virtual interfaces for dynamic OSPF routes. Zero config and DHCP can be used to generate route addresses, or a primary and secondary address can be manually set. |
Select the Add button to define a new set of virtual interface basic settings, or Edit to update the settings of an existing virtual interface configuration.
