A stored
certificate can be used from a different managed device if you
prefer not to use an existing certificate or key. Device
certificates can be imported and exported to and from the controller
or service platform to a secure remote location for archive and
retrieval as required for other managed devices.
To configure trustpoints for use
with certificates:
Select
Launch
Manager from SSH RSA Key, RADIUS Certificate
Authority, or RADIUS Server Certificate parameters.
Select a
device from among those displayed to review its certificate
information.
Refer to
All
Certificate Details to review the
certificate's properties, self-signed credentials, validity
duration, and CA information.
To
optionally import a certificate, click the Import button at the bottom of the
Manage Certificates screen.
The Import New Trustpoint screen displays.
You can use this screen to import CA certificates, CRLs
and signed certificates to the controller or service
platform once the network credentials of the file
transfer have been defined.
Click
OK to import the defined trustpoint.
Click
Cancel to revert to the last saved
configuration.
