The T5 controller Radios screen utilizes separate tabs to display radio Summary, Statistics and WLAN Map data.
A T5 controller uses the operating system to manage its connected radio devices, as opposed to the WiNG operating used by NX service platforms. However, a T5 controller, once enabled as a supported external device, can provide data to WiNG to assist in a T5‘s management within a WiNG supported subnet populated by both types of devices. The Customer Premises Equipment (CPEs) are the T5 controller managed radio devices using the operating system. The tabs within the Radios section support these T5 managed CPE radio devices.
To view T5 controller managed CPE radio statistics:
| Name | Displays the administrator assigned name of each listed CPE radio 1 or radio 2 as its unique identifier. |
| Rx (Kbps) | Displays the listed CPE radio's receive data rate (in Kbps). Use this information to assess RF activity versus other T5 managed CPE radios in the same radio coverage area. |
| Rx Octets | Displays the number of octets (bytes) received with no errors by the listed T5 controller managed CPE radio. |
| Rx Packets | Lists the number of data packets received for the listed T5 managed CPE radio since this screen was last refreshed. |
| Tx (Kpbs) | Displays the listed CPE radio's transmit data rate (in Kbps). Use this information to assess RF activity versus other T5 managed CPE radios in the same radio coverage area. |
| Tx Octets | Displays the number of octets (bytes) transmitted with no errors by the listed T5 controller managed CPE radio. |
| Tx Packets | Lists the number of data packets transmitted from the listed T5 managed CPE radio since this screen was last refreshed. |
