To define a Smart RF policy:
| Smart RF Policy | Displays the name assigned to the Smart RF policy when it was initially created. The name cannot be modified as part of the edit process. |
| Smart RF Policy Enable | Displays a green check mark if Smart RF has been enabled for the listed policy. A red “X” designates the policy as being disabled. |
| Interference Recovery | Displays a green check mark if interference recovery has been enabled for the listed policy. A red “X” designates interference recovery being disabled. |
| Coverage Hole Recovery | Displays a green check mark if coverage hole recovery has been enabled for the listed policy. A red “X” designates coverage hole recovery being disabled. |
| Neighbor Recovery | Displays a green check mark if neighbor recovery has been enabled for the listed policy. A red “X” designates neighbor recovery being disabled. |
The Basic Configuration screen displays by default for new or modified Smart RF policies.
| Sensitivity | Select a radio button corresponding to the desired Smart RF sensitivity. The options
include , Medium, High, and Custom. Medium is the default setting. The Custom option allows an administrator to adjust the parameters and thresholds for Interference Recovery, Coverage Hole Recovery, and Neighbor Recovery. Using the Low, Medium (recommended), and High settings still allows these features to be utilized. |
| Smart RF Policy Enable | Select this option to enable Smart RF for immediate inclusion within an RF Domain. Smart RF is enabled by default. |
| Interference Recovery | Select this option to enable compensations from neighboring radios when radio interference is detected. When interference is detected, Smart RF first determines the power increase needed based on the signal to noise ratio for a client (as seen by the access point radio). If a client‘s signal to noise value is above the threshold, the transmit power is increased until the signal to noise rate falls below the threshold. This option is enabled by default. |
| Coverage Hole Recovery | Select this option to enable coverage compensation from neighboring radios when a radio coverage hole is detected within the Smart RF supported radio coverage area. When a coverage hole is detected, Smart RF first determines the power increase needed based on the signal-to-noise ratio for a client as seen by the access point radio. If a client‘s signal-to-noise value is above the threshold, the transmit power is increased until the signal-to-noise rate falls below the threshold. This option is enabled by default. |
| Neighbor Recovery | Select this option to enable Neighbor Recovery when a failed radio is detected within the Smart RF supported radio coverage area. Smart RF can provide automatic recovery by instructing neighboring APs to increase their transmit power to compensate for the coverage loss. Neighbor Recovery is enabled by default when the sensitivity setting is Medium. |
This feature is only supported on the tri-radio AP4xx and AP8533 model APs.| Enable Smart Sensor | Select to enable auto-provisioning of AP4XX and AP8533 APs as sensors. When enabled, 1/3 of the deployed APs' sensor radios are turned on automatically. |
| Algorithm Cell Size | Select this option to enable the use of an algorithmic function to identify the
sensor APs. The WiNG Smart-sensor feature uses an
algorithm to provision APs as sensor within a site (RF
Domain). The algorithm creates a cluster of cells based
on inputs from the Smart-RF neighbor table. Each cell in
the cluster represents an AP and adjacent cells are the
AP's neighbor. The algorithm then identifies APs with
best coverage area and provisions them as sensors.
However, the algorithmic calculations vary depending on
the cell size. The current implementation provides two
algorithms based on the cell size (dense/sparse). Select
the algorithm best suited for your deployment.
Note: The
Smart-sensor calibration is auto-triggered when
Smart-sensor is enabled for the first time. In case
the number of APs deployed has changed or if the AP
deployment pattern has changed and re-calibration is
needed, you will have to manually issue the 'trigger-smart-sensor on
<RF-DOMAIN-NAME>' command to
trigger the algorithm through the
CLI.
