Refer to the advanced profile‘s Miscellaneous menu item to set or override a profile‘s NAS configuration. The profile database on the RADIUS server consists of user profiles for each connected network access server (NAS) port. Each profile is matched to a username representing a physical port. When an access point, controller, or service platform authorizes users, it queries the user profile database using a username representative of the physical NAS port making the connection.
Access point LED behavior and RF Domain management can also be defined from the Miscellaneous screen.
To define or override a profile's miscellaneous configuration attributes:
The allowed port range is 1 to 65,535.
When a client device requests access to the network, the Cisco ISE RADIUS server presents the client with a URL where a device‘s compliance is checked for definition file validity (this form of file validity checking is called posture). The check verifies, for example, that the device's anti-virus or anti-spyware software is valid. If the device complies, it is allowed access to the network.
Enabling Bluetooth detection results in interference on the Access Point‘s 2.4 GHz radio when in WLAN mode. WLANs are susceptible to sources of interference by Bluetooth devices.
