Access Point Radio Power
Overrides
Use the Power screen to set or
override one of two power modes (3af or Auto) for a managed Access Point. When
Automatic is selected, the Access Point safely operates within available
power. Once the power configuration is determined, the Access Point configures its
operating power characteristics based on its radio model and power configuration.
An Access Point uses a complex
programmable logic device (CPLD). The CPLD determines proper supply
sequencing, the maximum power available and other status information. One of the
primary functions of the CPLD is to determine the Access Point's maximum power
budget. When an Access Point is powered on (or performing a cold reset), the CPLD
determines the maximum power provided by the POE device and the budget available to
the Access Point. The CPLD also determines the hardware SKU and the number of
radios.
If the Access Point's POE resource cannot provide sufficient power
(with all intended interfaces enabled), some of the following interfaces could be
disabled or modified:
- The Access Point's transmit and receive algorithms could be
negatively impacted
- The Access Point's transmit power could be reduced due to
insufficient power
- The Access Point's WAN port configuration could be changed
(either enabled or disabled)
The 802.11ax AP5XX and AP4XX model access points can be powered up with POE or through an external
power source. These APs support both IEEE 802.3af and 802.3at standards. If connected
to a POE AT power source (25W) or external power source, the APs operate in normal mode with full
performance. If connected to a POE AF power source (14.5W), the APs operate in low power mode with limited
performance.
Consider the following information before configuring the power mode of the AP4XX and AP5XX
model access points:
AP4XX (AP410i/e and
AP460i/e) power mode
To operate in the normal mode AP410 and AP460 have to be powered from:
- GE1 POE connected to AT switch,
or
- External power supply source
To operate in the
low power mode AP410 and AP460
- GE1 POE connected to AF switch
port and external power supply not connected.
Low power mode limitations
are as follows:
- For AP410i: USB port is
turned OFF and Radio 2 (5 GHz) is limited to 2x2 with max power of
20dBm.
- For AP410e: USB port is
18dBm.
- For AP460i: Radio 2 (5 GHz)
is limited to 2x2 with max power of 22dBm.
- For AP460e: Radio 2 (5 GHz)
is limited to 2x2 with max power of 20dBm.
AP5XX (AP510i/eand AP560i/h) power
mode
To operate in the
normal mode
AP510 and AP560 have to be powered from:
port and GE2 is not connected, or
- GE2 POE connected to AT switch
port and GE1 is not connected, or
- Both GE1 and GE2 POE connected
to AT switch port, or
source
To operate in the
low power
mode AP510 and AP560 have to be powered from:
port and external power source not connected, or
- GE2 POE connected to AF switch
Low power
mode limitations are as follows:
- For AP510:
- Mode 1: Radio 1 (2.4
GHz) and Radio 2 (5 GHz) is limited to 2x2 with max power of
20dBm.
- Mode 2: Radio 1
(sensor) and Radio 2 (5 GHz) is limited to 2x2 with max power of
20dBm.
- Mode 3: Radio 1 (5
GHz) is limited to 2x2 with max power of 18dBm and Radio 2 (5 GHz) is
limited to 2x2 with max power of 0dBm (providing no service).
- For AP560:
16dBm.
- Mode 2: Radio 1
16dBm.
AP505 mode of functioning
(normal/low power):
To operate in the
normal mode
AP505 has to be powered from:
port, or
source
To operate in the
low power
mode AP505 has to be powered from:
Low power
- Mode 1: Radio 1 (2.4 GHz)
and Radio 2 (5 GHz) is limited to 2x2 with max power of 18dBm.
To define an access point‘s power
configuration:
- Select
the .
- Select an AP profile. The selected profile's
configuration menu diplays.
- Select Power.
- Use the Power
Mode drop-down menu to set or override the Power
Mode Configuration on this AP.
on for the first time, the system determines the power budget
available to the Access Point. Using the Automatic setting,
the Access Point automatically determines the best power
configuration based on the available power budget. Automatic
is the default setting.
If 802.3af is selected, the
Access Point assumes 12.95 watts are available. If the mode is
changed, the Access Point requires a reset to implement the
change. If 802.3at is selected, the Access Point assumes 23 -
26 watts are available.
- Set or override the Access Point radio‘s 802.3af Power Mode and the radio‘s 802.3at
Power Mode.
- Use the drop-down menu to define a
mode of either Range
or Throughput.
- Select Throughput to
transmit packets at the radio‘s highest defined basic rate (based on the radio‘s
current basic rate settings). This option is optimal in environments where the
transmission range is secondary to broadcast/multicast transmission performance.
- Select Range when range is
preferred over performance for broadcast/multicast (group) traffic. The data rates
used for range are the lowest defined basic rates. Throughput is the default setting
for both 802.3af and 802.3at.
- Click OK to save the changes
and overrides made to the Access Point power configuration. Click Reset to revert to the
last saved configuration.
