An encrypted string alias maps a user-friendly name to a string value. The string value displays as encrypted text when "password-encryption" is enabled. Encrypted-string aliases can be used for string configuration parameters that are encrypted by the "password-encryption" feature.
To configure an encrypted string alias on an access point:
The encrypted string alias configuration screen displays.
Name |
Provide a name for the encrypted string alias. Note:
The alias name should start with a dollar sign ($), and not exceed 32 characters in length. |
Value |
Enter the string value associated with the alias name provides above. |
Click Reset to revert the screen back to its last saved configuration.
