Use the following procedure to configure Fabric Extend (FE) between a Main office to a Branch office. This is a typical deployment. However, if your deployment creates tunnels between two switches that support Fabric Extend natively, repeat those steps and ignore the steps for switches that require an ONA.
VRF is an optional parameter. If a VRF is not configured, then FE uses the GRT.
Configuring Fabric Extend consists of two primary tasks: configuring the tunnel source address and configuring the logical interface. These tasks must be completed on both ends of the tunnel.
The VSP 4450 Series source address command is different than other platforms. The logical interface commands are different between Layer 2 and Layer 3 networks.
The following steps are for platforms that support FE natively:
The following steps are for platforms that require an ONA to support FE:
The interface VLAN connecting to the ONA network port is always in the GRT, and the member port that the VLAN is part of is always an access port.
Use the data in the following table to use the Logical Interfaces tab and the Insert Logical Interfaces dialog. The available fields in the dialog differ depending on the type of core you select: layer 2 or ip.
Name |
Description |
Id |
Specifies the index number that uniquely identifies this logical interface. This field displays on the Insert Logical Interfaces dialog only. |
IfIndex |
Specifies the index number that uniquely identifies this logical interface. This field is read-only. This field displays on the Logical Interfaces tab only. |
Name |
Specifies the administratively assigned name of this logical interface, which can be up to 64 characters. |
Type Note:
Exception: Type Layer 2 is not supported on XA1400 Series. |
Specifies the type of logical interface to create:
DestIPAddr |
Specifies the destination IP address for the IP-type logical interface. |
DestIfIndex Note:
Exception: Not supported on XA1400 Series. |
Specifies the physical port or MultiLink Trunking (MLT) that the Layer 2 logical interface is connected to. |
Vids Note:
Specifies the list of VLANs that are associated with this logical interface. |
PrimaryVid Note:
Specifies the primary tunnel VLAN ID associated with this Layer 2 Intermediate-System-to-Intermediate-System (IS-IS) logical interface. |
CircIndex Note:
Identifies the IS-IS circuit created under the logical interface. This field displays on the Logical Interfaces tab only. |
NextHopVrf Note:
Identifies the next-hop VRF name to reach the logical tunnel destination IP. This field displays on the Logical Interfaces tab only. |
IpsecEnable Note:
Exception: Only supported on XA1400 Series. |
Specifies whether the logical interace should use IPsec. |
AuthenticationKey Note:
Specifies the authentication key of this logical interface, which can be up to 32 characters. |
ShapingRate Note:
Specifies the value, in Mbps, of the Egress Tunnel Shaper applied to the logical interface. |
Mtu |
Specifies the Maximum Transmission Unit (MTU) size for each logical interface. The default MTU value is 1950. |
EncryptionKeyLength Note:
Specifies the IPsec encryption key length for FE tunnel, which can be 128 bit or 256 bit. The default value is len128bit. |
IpsecTunnelDestAddress Note:
Specifies the destination IP address for the IPsec tunnel. |
| BfdEnable Note: Exception: Not
supported on VSP 8600
Series or VSP 4450
Series.
Enables or disables BFD on an IS-IS Logical Interface. |
IpsecResponderOnly Note:
Specifies whether the device is a Responder device in an IPsec Network Address Translation Traversal (NAT-T) connection. |
| IpsecRemoteNatIPAddr Note:
Specifies the public IP address of the NAT router connected to the Responder device in an IPsec NAT-T connection. |
IpsecAuthMethod Note:
Configures the IPsec authentication method for the tunnel as either a pre-shared key or RSA signature for digital certificates. The default is pre-shared key. |
IpsecCompression Note:
Reduces the size of the IP datagram to improve the communication performance between hosts connected behind Backbone Edge Bridges (BEB). Tip:
As a best practice, use IPsec compression only for Fabric Extend tunnels where latency is greater than 70ms. |
