This procedure only applies to VSP 8600 Series. For other products, see Segmented Management Instance Configuration for VOSS using EDM.
Configure IPv6 management port parameters to use IPv6 routing on the port.
This procedure only applies to hardware with a dedicated, physical management interface.
- In the Device Physical View tab, select the management port.
- Select Mgmt Port.
- Select the IPv6 Interface tab.
- Select Insert.
- Edit the fields as required.
- Select Insert.
- Select Apply.
IPv6 Interface field descriptions
Use the data in the following table to use the IPv6 Interface tab.
| Name | Description |
| Interface | Identifies the unique IPv6 interface. |
| Descr | Specifies a textual string containing information about the interface. The network management system also configures the Descr string. |
| Type | Specifies the type of interface. |
| ReasmMaxSize(MTU) | Configures the MTU for this IPv6 interface. This value must be the same for all the IP addresses defined on this interface. The default value is 1500. |
| PhysAddress | Specifies the physical address for the interface. For example, for an IPv6 interface attached to an 802.x link, this value is a MAC address. |
| AdminStatus | Configures the indication of whether IPv6 is activated (up) or disabled (down) on this interface. This object does not affect the state of the interface, only the interface connection to an IPv6 stack. The default is false (cleared). |
| ReachableTime | Configures the time, in milliseconds, that the system considers a neighbor reachable after it receives a reachability confirmation. The value is in a range from 0–3600000. The default value is 30000. |
| RetransmitTimer | Configures the time between retransmissions of neighbor solicitation messages to a neighbor; during address resolution or neighbor reachability discovery. The value is expressed in milliseconds in a range from 0–3600000. The default value is 1000. |
| CurHopLimit | Specifies the current hop limit field sent in router advertisements from this interface. The value must be the current diameter of the Internet. A value of zero indicates that the advertisement does not specify a value for the current hop limit. The default is 64. |
