The switch uses RADIUS servers for authentication and accounting services. Use the no form to delete a RADIUS server.
- You must enable EAP globally.
The RADIUS server uses the secret key to validate users.
RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration.
Switch:1> enable
Switch:1# configure terminal
Add an EAP RADIUS server:
Switch:1(config)# radius server host fe80:0:0:0:21b:4fff:fe5e:73fd key radiustest used-by eapol
The following table defines parameters to configure an EAP-enabled RADIUS server with the radius server host command.
| Variable | Value |
| host WORD<0–46> | Specifies the IP address of the selected server. RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration. |
| WORD<0-20> | Specifies the secret key, which is a string of up to 20 characters. |
The following table defines parameters to use optional arguments of the radius server host command.
| Variable | Value |
| port <1-65535> | Specifies the port ID number. |
| priority <1-10> | Specifies the priority number. The lowest number is the highest priority. |
| retry <0-6> | Specifies the retry count of the account. |
| timeout <1-180> | Specifies the timeout of the server. The default is 30. |
| enable | Enables the functions used by the RADIUS server host. |
| acct-port <1-65536> | Specifies the port account. |
| acct-enable | Enables the account. |
| secure-enable | Enable secure mode on the server. |
| secure-log-level | Specifies the RADIUS secure server log severity level. Possible values are:
| secure-mode | Specifies the protocol for establishing the secure connection with the server. |
| secure-profile | Specifies the secure profile name. |
| source-ip
                                                  WORD<0–46> Note:
                                                   Exception: only supported on VSP 8600 Series. | Specifies the IP source. RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration. |
