Use this procedure to view global LLDP information, to know which LLDP settings and parameters are configured.
View global LLDP information:
Switch:1#show lldp
802.1ab Configuration:
             TxInterval: 30
       TxHoldMultiplier: 4
            ReinitDelay: 1
                TxDelay: 1
   NotificationInterval: 5
      View the LLDP local system data on the switch:
Switch:1#show lldp local-sys-data
                             LLDP Local System Data
               ChassisId: MAC Address        b0:ad:aa:4c:54:00
               SysName  : LLDP agent
               SysDescr : VSP-4450GSX-PWR+ (6.0.1.0)  BoxType: VSP-4450
               SysCap   : Br / Br
Capabilities Legend: (Supported/Enabled)
B= Bridge,    D= DOCSIS,    O= Other,     R= Repeater,
S= Station,   T= Telephone, W= WLAN,      r= Router
      View the LLDP neighbor information. You can also view this on a specific port.
Switch:1#show lldp neighbor
                                      LLDP Neighbor
Port: 1/28      Index    : 1                  Time: 0 day(s), 01:16:25
                Protocol : LLDP
                ChassisId: MAC Address        a4:25:1b:52:54:00
                PortId   : MAC Address        a4:25:1b:52:54:1b
                SysName  : BEB
                SysCap   : Br / Br
                PortDescr: VSP8404 - Gbic1000BaseT Port 1/28
                SysDescr : VSP8404 (4.5.0.0)
                Address  : 192.0.2.47
Total Neighbors : 1
      View the LLDP neighbor summary of all ports on the switch. You can also view this on a specific port.
The EDM tab ( displays only IPv4 addresses. Use CLI to see both IPv4 and IPv6.
Switch:1#show lldp neighbor summary
                                                 LLDP Neighbor Summary
LOCAL            IP/IPv6         CHASSIS            REMOTE
PORT       PROT  ADDR            ID                 PORT               SYSNAME       SYSDESCR
1/4        LLDP  0.0.0.0         f8:15:47:e1:dd:00  f8:15:47:e1:dd:06  VSP-4450GSX-~ VSP-4450GSX-PWR+ (6.0.1.0)
1/12       LLDP  192.0.2.77     a4:25:1b:53:6c:00  a4:25:1b:53:6c:28  VSP-7254XTQ   VSP-7254XTQ (6.0.0.0)
1/13       LLDP  192.0.2.34     00:14:0d:e3:40:00  00:14:0d:e3:40:c1  ERS-8606      ERS-8606 (7.2.10.1)
1/14       LLDP  192.0.2.78     a4:25:1b:52:34:00  a4:25:1b:52:34:28  VSP-7254XSQ   VSP-7254XSQ (6.0.0.0)
1/24       LLDP  192.0.2.94     00:13:65:a3:8c:00  00:13:65:a3:8c:18                Ethernet Routing Switch 5520-~
1/25       CDP   192.0.2.89     --                 FastEthernet2/0/5  cisco3750.Tr~ cisco WS-C3750-48P running on~
1/27       CDP   0.0.0.0         --                 FastEthernet3/0/6  Switch        cisco WS-C3750-48TS running o~
1/48       LLDP  192.0.2.76     b0:ad:aa:4e:dc:00  b0:ad:aa:4e:dc:68  VSP-8404      VSP-8404 (6.0.0.0)
Total Neighbors : 8
      View the LLDP administrative status of all ports on the switch. You can also view this on a specific port.
Switch:1#show lldp port
                             LLDP Admin Port Status
Port       AdminStatus  ConfigNotificationEnable  CdpAdminState
1/1        txAndRx      disabled                  disabled
1/2        txAndRx      disabled                  disabled
1/3        txAndRx      disabled                  disabled
1/4        txAndRx      disabled                  disabled
      View the LLDP reception statistics. You can also view this on a specific port.
Switch:1#show lldp rx-stats
                                 LLDP Rx-Stats
Port      Frames      Frames   Frames   TLVs        TLVs           AgeOuts
Num       Discarded   Errors   Total    Discarded   Unsupported
                                        (Non FA)    (Non FA)
1/1       0           0        0        0           0              0
1/2       0           0        0        0           0              0
1/3       0           0        0        0           0              0
1/4       0           0        0        0           0              0
      View the LLDP statistics:
Switch:1#show lldp stats
                                   LLDP Stats
Inserts    Deletes    Drops      Ageouts
4          0          0          0
      View the LLDP transmission statistics:
Switch:1#show lldp tx-stats
                                 LLDP Tx-Stats
PORT NUM                 FRAMES
1/1                      95
1/2                      95
1/3                      95
1/4                      95
1/5                      95
      Display LLDP-MED local system data:
Switch:1#show lldp local-sys-data med
               ChassisId: MAC Address        d4:78:56:f1:65:00
               SysName  : VSP-4450GSX-PWR+
               SysDescr : VSP-4450GSX-PWR+ (w.x.y.z)
               SysCap   : Br / Br
        MED Capabilities:       CNLSI
        MED Device Type:        Network Connectivity Device
        MED Power Device Type:  PSE Device
        HWRev: 03               FWRev: VU-Boot 2012.04-00034-g57194a8
        SWRev: v5.7.3.005       SerialNumber: 16JP1160E51D
        ManufName: Extreme Networks. ModelName: VSP-4450GSX-PWR+
        Asset ID: 16JP1160E51D
Port: 1/1
  MED Enabled Capabilities: CNLI
  MED Network Policy:
    Application Type: Voice
      VLAN ID: 412
      L2 Priority: 3
      DSCP Value: 57
      Tagging: Tagged Vlan
      Policy defined
    Application Type: Voice-Signaling
      VLAN ID: 7
      L2 Priority: 6
      DSCP Value: 24
      Policy defined
  MED Location - Coordinate-based LCI:
    Latitude:  +12.3 (degrees) North
    Longitude: +42   (degrees) East
    Altitude:  +45   (meters)
    Datum: World Geodesic System (WGS84)
  MED Location - Civic Address LCI:
    Country code: RO
    Country: Romania
    City: Bucuresti
    Block: 12
    Street: Calea Floreasca
    Floor: 3
  MED Location - Emergency Call Service ELIN:
    ECS ELIN: 121416182022
  MED Extended Power via MDI:
    Power Value: 16.0 Watt
    Power Type: PSE
    Power Source: Primary
    Power Priority: Low
MED Capabilities Legend: (Supported/Enabled)
  C= Capabilities, N= Network Policy; L= Location Identification;
  I= Inventory; S= Extended Power via MDI - PSE; D= Extended Power via MDI - PD.
The following table defines parameters for the show lldp command.
| Variable | Value |
| local-sys-data | Displays the LLDP local system data. |
| neighbor [summary] [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] | Displays the LLDP neighbor system information. You can also view this on a specific port. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| port [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] | Displays the LLDP administrative status of a port or all ports on the switch. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| rx-stats [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] | Displays the LLDP reception statistics on all ports on the switch, or on a specific port. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| stats | Displays the LLDP statistics. |
| tx-stats [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] | Displays the LLDP transmission statistics on all ports on the switch or on a specific port. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
