This procedure does not apply to VSP 8600 Series.
Use the following procedure to view key health information about the types of control packets and protocols received on a port and sent to the segmented management instance interace.
- Expand Mgmt Instance.
- Select Stats
- Select the KHI tab.
- To clear KHI statistics for a management interface, select an InstanceId and select Clear Stats.
KHI Field Descriptions
Use the data in the following table to use the KHI tab.
Name |
Description |
InstanceId |
Shows the management interface instance. |
PacketType |
Shows the packet type. |
PacketName |
Shows the name of the packet. |
RxPackets |
Shows the number of received packets on the port for the packet type. |
TxPackets |
Shows the number of transmitted packets on the port for the packet type. |
| RxDropped | Shows the number of received packets dropped on the port for the packet type. |
