View the DvR backbone entries (redistributed host routes) learned from all Controllers in all DvR domains.
You can view DvR backbone entries only on a Controller. Viewing backbone entries does not apply to a Leaf node.
Ensure that you enable DvR globally on the node.
- In the navigation pane, expand folders.
 - Select DVR.
 - Select the Backbone Entries tab.
 - Optional: To filter the rows based on the specific criteria, click Filter.
Backbone Entries field descriptions
Use the data in the following table to use the Backbone Entries tab.
 Name  |
 Description  |
 IpAddrType  |
 Specifies the address type of the DvR backbone host (IPv4 remote ARP).  |
 IpAddr  |
 Specifies the IPv4 address of the DvR backbone host.  |
 L3Isid  |
 Specifies the Layer 3 I-SID of the DvR backbone host.  |
 DomainId  |
 Specifies the domain ID of the DvR backbone host.  |
 EcmpIndex  |
 Specifies the ECMP index of the DvR backbone host.  |
 HostMacAddr  |
 Specifies the MAC address of DvR backbone host.  |
 L2Isid  |
 Specifies the Layer 2 I-SID of the DvR backbone host.  |
 AdvControllerName  |
 Specifies the host name of the advertising Controller.  |
 AdvController  |
 Specifies the host MAC address of the advertising Controller.  |
 NextHopName  |
 Specifies the host name of the next hop Backbone host in the DvR route.  |
 NextHopMac  |
 Specifies the MAC address of the next hop Backbone host in the DvR route.  |
