Perform this procedure to configure the egress shaping rate for IPsec tunnels on Fabric IPsec Gateway Virtual Machine (VM).
Before you can configure the egress shaping rate for the IPsec tunnel on the VM, you must first disable the IPsec tunnel.
enable
virtual-service WORD<1-128> console
Type CTRL+Y to exit the console.
delete ipsec <1-255> admin-state enable
set ipsec <1-255> egress-shaping-rate <1-1000>
set ipsec <1-255> admin-state-enable
Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> delete ipsec 1 admin-state enable FIGW> set ipsec 1 egress-shaping-rate 200 FIGW> set ipsec 1 admin-state enable
