Clear all IPv6 statistics if you do not require previous statistics.
Use the information in the following table to use the clear ipv6 statistics commands.
Variable |
Value |
gigabitethernet {slot/port[/sub-port]} |
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
loopback <1–256>> |
Identifies a loopback interface. |
mgmtethernet mgmt Note:
Exception: only supported on VSP 8600 Series. |
Identifies the management interface. This parameter only applies to hardware with a dedicated, physical management interface. |
tunnel <1-2000> |
Identifies a 6in4 tunnel ID. |
vlan<1-4059> |
vrf WORD<1–16> |
Specifies the VRF name. |
vrfids WORD<0–512> |
Specifies the VRF ID. |
