View the DvR interfaces on either a Controller or a Leaf node.
On Controllers, DvR interfaces are created when you configure IP on a DvR enabled Layer 2 VSN (VLAN, I-SID). Only Controllers display the administrative state of the interfaces because this is where you enable or disable the interfaces. The Leaf nodes display DvR interface information that is pushed from the Controllers, for example, subnet routes or gateway IP addresses for the Layer 2 VSNs.
Ensure that you enable DvR globally on the node.
View DvR interfaces on a Controller node:
You can view DvR interface information on all interfaces or for a specific Layer 3 I-SID, VRF, or VRF ID.
Switch:1#show dvr interfaces
DVR Interfaces
Admin SPBMC IGMP
Interface Mask L3ISID VRFID L2ISID VLAN GW IPv4 State State Version
50.0.1.2 255.255.0.0 55500 1 50500 500 50.0.1.1 enable disable 2
1 out of 1 Total Num of DVR Interfaces displayed
View DvR interfaces on a Leaf node:
You can view DvR interface information on all interfaces or for a specific Layer 3 I-SID. Viewing the interface information for a specific VRF or VRF ID is not supported on a DvR Leaf node.
Switch:1#show dvr interfaces l3isid 401
DVR Interfaces
40.1.0.0 255.255.0.0 401 2 10401 77 40.1.1.11
40.2.0.0 255.255.0.0 401 2 10402 78 40.2.1.11
40.3.0.0 255.255.0.0 401 2 10403 79 40.3.1.11
40.4.0.0 255.255.0.0 401 2 10404 80 40.4.1.11
4 out of 4 Total Num of DVR Interfaces displayed
Variable definitions
Use the data in the following table to use the show dvr interfaces command.
Variable |
Value |
l3isid |
Specifies the Layer 3 I-SID of the DvR interface. The range is 0 to 16777215. |
vrf |
Specifies the VRF name. |
vrfids |
Specifies the VRF ID. The range is 0 to 512. |
