Modify the ingress Differentiated Services Code Point (DSCP) to QoS mappings to change traffic priorities. As a best practice, use the default mappings. Changes to the mapping table take effect after you restart the system.
Do not change the default values. If you change the values, make sure that the values are consistent on all other devices in the network. Inconsistent mapping of table values can result in unpredictable service levels.
 - Click Mapping Tables.
 - Click the Ingress Dscp To QoS tab.
 - Double-click a QosLevel field to change the value.
 - Click Apply.
Ingress Dscp To QoS field descriptions
Use the data in the following table to use the Ingress Dscp To QoS tab.
 Name  |
 Description  |
 InDscp  |
 Specifies the value of the DiffServ codepoint (in decimal format) in the IP header of the incoming packet.  |
 InDscpBinaryFormat  |
 Specifies the value of the DiffServ codepoint (in binary format) in the IP header of the incoming packet.  |
 QosLevel  |
 Specifies the equivalent QoS level.  |
