You can display current IPv6 BGP+ route information.
Bgp Route Summary field descriptions
Use the data in the following table to use the Bgp Route Summary tab.
Name | Description |
Prefix | Specifies the IP address prefix in the Network Layer Reachability Information (NLRI) field. This is an IP address that contains the prefix with a length specified by IpAddrPrefixLen. Any bits beyond the length specified by IpAddrPrefixLen are set to zero. |
PrefixLen | Specifies the length, in bits, of the IP address prefix in the NLRI field. |
LocalAddr | The local address of this entry's BGP connection. |
RemoteAddr | Specifies the IP address of the peer from which path information was learned. |
