View application host statistics to see traffic statistics by application protocol for each host.
Switch:1# show rmon application-host-stats ? WORD<1-64> Select one of these application protocols {TCP|UDP|FTP|TELNET|HTTP|RLOGIN|SSH|TFTP|SNMP|HTTPS} Switch:1# show rmon application-host-stats FTP ================================================================================ Rmon Application Host Stats ================================================================================ HOSTADDR INPKT OUTPKT INOCT OUTOCT CREATETIME -------------------------------------------------------------------------------- 192.0.2.10 0 0 0 0 10/09/15 17:29:54
Protocol support can vary across platforms.
The following table defines parameters for the show rmon application-host-stats command.
Variable | Value |
WORD<1–64> Note:
Exception: the rlogin application is only supported on VSP 8600 Series. However, RMON2 counts application packets received on any platform on which the application is not enabled or supported, before dropping them. |
Specifies one of the following application protocols: TCP, UDP, FTP, TELNET, HTTP, rlogin, SSH, TFTP, SNMP, HTTPS. |
