The following considerations apply to ZTP+:
Fabric configurations are not supported with ZTP+. After ZTP+ is configured, Extreme Management Center server can use Simple Network Management Protocol (SNMP) to remotely configure Fabric-related configurations on the switch using SNMP MIBs.
Only the OOB port or the Management VLAN interface are used to connect the Extreme Management Center server.
ZTP+ cannot change the Management VLAN interface. If onboarding started on the Management onboarding VLAN, this cannot be changed while using ZTP+.
