Feature |
Product |
Release introduced |
MSTP-Fabric Connect Multi Homing |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
VSP 4450 Series |
VOSS 7.0 |
VSP 4900 Series |
VOSS 8.1 |
VSP 7200 Series |
VOSS 7.0 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VOSS 7.0 |
VSP 8400 Series |
VOSS 7.0 |
VSP 8600 Series |
Not Supported |
XA1400 Series |
Not Supported |
The MSTP-Fabric Connect Multi Homing feature allows MSTP or RSTP network to be multi-homed into a Fabric Connect network, providing a loop-free topology. MSTP-Fabric Connect Multi Homing enables an MSTP network to be multihomed into the SPB Fabric network through single node-to-multiple nodes or multiple nodes-to-multiple nodes.
Important
You must enable MSTP-Fabric Connect Multi Homing before you establish multihoming with an MSTP network.
MSTP-Fabric Connect Multi Homing uses I-SID 16777003. The switch creates this I-SID automatically and it cannot be modified.
MSTP-Fabric Connect Multi Homing is supported on SPBM mode only.
