The virtual services running on a Virtual Machine (VM) require a console for configuration and monitoring purposes.
Perform this procedure to access the virtual service console port for the specific VM.
Switch:1>enable Switch:1#virtual-service tpvm console
Use data in the following table to use the virtual-service command.
Variable |
Value |
WORD<1-80> |
Specifies the virtual service name. |
console |
Accesses the console for the specific virtual service. |
