The front panel view of Enterprise Device Manager (EDM) provides additional information for Power over Ethernet (PoE) ports for the following PoE switches:
5420F-24P-4XE
5420F-8W-16P-4XE
5420M-24W-4YE
5420M-48W-4YE
5420F-48P-4XE
5420F-16W-32P-4XE
5420F-48P-4XL
5420F-16MW-32P-4XE
5420M-16MW-32P-4YE
5520-12MW-36W
5520-24W
5520-48W
VSP4900-48P
VSP4900-12MXU-12XE
VSP 4450 Series
This additional information is in the form of a colored P that displays inside the graphic representation of the port. This colored P represents the current power aspect of the PoE port.
Color |
Description |
Green |
The port is currently delivering power. |
Red |
The power and detection mechanism for the port is disabled. |
Orange |
The power and detection mechanism for the port is enabled. The port is not currently delivering power. |
White/Gray |
The power and detection mechanism for the port is unknown. |
Important
The data and power aspect coloring schemes are independent of each other. You can view the initial status for both data and power aspect for the port. To refresh the power status, right-click the unit, and select Refresh Port Tooltips from the shortcut menu.
