The system supports reverse path checking only on ports that have a valid IP address.
Configure reverse path checking on a port to determine if a packet IP address is verifiable. Use reverse path checking to reduce the problems that are caused by the introduction of malformed or forged (spoofed) IP source addresses into a network. After you enable reverse path checking, the switch performs a reverse path check to determine if the packet IP address is verifiable. If the address is not verifiable, the system discards the packet.
Reverse path checking operates in one of two modes:
exist-only mode
strict mode
- In the Device Physical View tab, select a port.
- Click IPv6.
- Click the Reverse Path Checking tab.
- Select theReversePathCheckEnable check box to enable reverse path checking.
- Select exist-only or strict.
- Click Apply.
Reverse Path Checking field descriptions
Use the data in the following table to use the Reverse Path Checking tab.
Name |
Description |
ReversePathCheckEnable |
Enables reverse path checking on the selected port. The default is disabled. |
ReversePathCheckMode |
Specifies the mode for reverse path checking. The modes are
The default is exist-only. |
