Use the following procedure to view statistical graph of the IS-IS interface counters.
- Select IS-IS.
- Select the Interfaces tab.
- Select an interface.
- Select the Graph button.
Interface Counters field descriptions
The following table describes the fields in the Interface Counters tab.
Name |
Description |
InitFails |
Indicates the number of times initialization of this circuit has failed. This counts events such as PPP NCP failures. |
RejAdjs |
Indicates the number of times an adjacency has been rejected on this circuit. |
IDFieldLenMismatches |
Indicates the number of times an Intermediate-System-to-Intermediate-System (IS-IS) control PDU with an ID field length different from that for this system has been received. |
MaxAreaAddrMismatches |
Indicates the number of times an IS-IS control PDU with a max area address field different from that for this system has been received. |
AuthFails |
Indicates the number of times an IS-IS control PDU with the correct auth type has failed to pass authentication validation. |
LANDesISChanges |
Indicates the number of times the Designated IS has changed on this circuit at this level. If the circuit is point to point, this count is zero. |
AbsoluteValue |
Displays the counter value. |
Cumulative |
Displays the total value since you opened the Stats tab. |
Average/Sec |
Displays the average value for each second. |
Minimum/Sec |
Displays the minimum value for each second. |
Maximum/Sec |
Displays the maximum value for each second. |
Last Val/Sec |
Displays the last value for each second. |
