Use the Trap Sender Table tab to view source and receiving addresses.
- Click Chassis.
- Click the Trap Sender Table tab.
Trap Sender Table Field Descriptions
Use the data in the following table to use the Trap Sender Table tab.
| Name | Description |
| RecvAddress | IP address for the trap receiver. This is a read-only parameter that contains the IP address configured in the TAddress field in the TargetTable. |
| SrcAddress | Source IP address to use when sending traps. This IP address will be inserted into the source IP address field in the UDP trap packet. |
