Use the following procedure to configure a collector for IPFIX. Use the ExtremeAnalytics™ solution as the collector.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#ip ipfix collector 1 192.0.2.15 exporter-ip 192.0.2.16 dest-port 2 src-port 4 Switch:1(config)#ip ipfix collector 1 export-interval 40 Switch:1(config)#ip ipfix collector 1 initial-burst 4
Use the data in the following table to use the ip ipfix collector command.
Variable |
Value |
<1–1> |
Specifies the IPFIX collector ID. |
{A.B.C.D} |
Specifies the IP address of the collector. |
exporter-ip {A.B.C.D} |
Specifies the IP address of the exporter. |
dest-port <1-65535> |
Specifies the destination port receiving flow information. |
src-port <1-65535> |
Specifies the source port sending flow information. |
export-interval |
Specifies, in seconds, the frequency of template packet exports to the collector. The default value is 60 seconds. |
initial-burst |
Specifies the number of template packets sent when the collector becomes reachable. The default value is 5. |
