You cannot configure a platform VLAN directly on a DvR leaf node. However, you can configure a VLAN Management Instance on a DvR leaf node. After you configure the management VLAN, you can configure a platform VLAN.
The following table defines parameters for the mgmt vlan command.
| Variable | Value |
<2-4059> |
Specifies the existing port-based VLAN ID to associate with the management VLAN. |
The following table defines parameters for the vlan create command.
| Variable | Value |
<2-4059> |
Specifies the VLAN ID in the range of 2 to 4059. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. By default, the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. |
name WORD<0-64> |
Specifies the VLAN name. The name attribute is optional. |
type port-mstprstp <0-63> [color <0-32>] |
Creates a VLAN by port:
Note:
MSTI instance 62 is reserved for SPBM if SPBM is enabled on the switch. |
