View the members of all DvR domains namely the Controllers and Leaf nodes.
You can view this information on either a Controller or a Leaf node. Both the Controller and the Leaf node displays the members of the DvR domain to which it belongs.
Ensure that you enable DvR globally on the node.
- Select DVR.
- Select the Members tab.
- Optional: To filter the rows based on specific criteria, click Filter.
Members field descriptions
Use the data in the following table to use the Members tab.
Name |
Description |
MacAddress |
Specifies the system ID or the nodal MAC address of this DvR member. |
SysName |
Specifies the system name of this DvR member. |
NickName |
Specifies the nick name of this DvR member. |
Role |
Specifies the DvR role (Controller or Leaf) of this DvR member. |
DomainId |
Specifies the domain ID of the DvR domain that this member belongs to. |
