Use the following procedure to view the DHCP Snooping interface information.
show ip dhcp-snooping interface [ gigabitEthernet [ {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} [ vrf WORD<1-16> | vrfids WORD<0-512> ] | <1-4059> [ {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} [ vrf WORD<1-16> | vrfids WORD<0-512> ] | vrf WORD<1-16> | vrfids WORD<0-512> ] | vrf WORD<1-16> | vrfids WORD<0-512> ] ]
show ip dhcp-snooping vlan <1-4059>
show ip dhcp-snooping vrf WORD<1-16>
show ip dhcp-snooping vrfids WORD<0-512>
Switch:1>show ip dhcp-snooping interface gigabitEthernet
Dhcp Snooping Interface Info
PORT PORT TRUNK
NUM CLASS ID
1/1 UNTRUSTED none
1/2 UNTRUSTED none
2/1 UNTRUSTED none
2/2 UNTRUSTED none
2/3 UNTRUSTED none
2/4 UNTRUSTED none
2/5 UNTRUSTED none
2/6 UNTRUSTED none
2/7 UNTRUSTED none
2/8 UNTRUSTED none
2/9 UNTRUSTED none
2/10 UNTRUSTED none
2/11 UNTRUSTED none
2/12 UNTRUSTED none
2/13 UNTRUSTED none
2/14 UNTRUSTED none
All 16 out of 16 Total Num of Dhcp Snooping entries displayed
Switch:1>show ip dhcp-snooping vlan
Dhcp Snooping Vlan Info
VLAN VRF
ID NAME ENABLE ORIGIN
1 GlobalRouter false RADIUS
10 GlobalRouter false RADIUS
4051 GlobalRouter false RADIUS
4052 GlobalRouter false RADIUS
All 4 out of 4 Total Num of Dhcp Snooping entries displayed
Switch:1>show ip dhcp-snooping binding vrfids 0
DHCP Snooping Binding Table
MAC IP PORT VLAN VRF LEASE EXPIRY ENTRY
ADDRESS ADDRESS NUM ID NAME TIME TIME TYPE
36:63:0e:73:03:fe 192.0.2.8 2/10/2 200 GlobalRouter 86400 83700 Learned
36:63:0e:73:03:ff 192.0.2.9 2/10/2 200 GlobalRouter 86400 83700 Learned
Static entries : 0
Learned entries : 2
Total entries : 2
All 2 out of 2 Total DHCP Snooping binding entries displayed
Switch:1>show ip dhcp-snooping binding vrf vrf100
00:00:00:00:01:01 192.0.2.11 2/30 100 vrf100 Infinite none Static
Static entries : 1
Learned entries : 0
Total entries : 1
All 1 out of 3 Total DHCP Snooping binding entries displayed
