Use this procedure on a VOSS switch to change the Network Operating System (NOS) personality.
The primary method to select a NOS personality for the switch is by using ExtremeCloud IQ. If the network is not accessible, or if you do not use Extreme Networks management software, you can change the NOS personality by using VOSS CLI commands.
Use FTP to transfer the NOS image to the /intflash/ directory in the VOSS file system.
If you change the NOS personality, the system deletes all configuration, licensing, and log files that pertain to the previous NOS personality.
If a power interruption occurs during a personality change, the system restarts the process after you restore power to the switch.
As part of the NOS personality change, you must restart the switch. If, during the restart, the system detects a failure, the NOS personality does not change. After the original NOS restarts, it logs an error message and raises a persistent alarm.
You can store only two software releases on 5420 Series and 5520 Series. If you attempt to add a third software release, you are promted for a confirmation to overwrite the non-primary release. You can also use the software add <filename> -y command to bypass the confirmation question and automatically overwrite the non-primary release.
Change the NOS personality to ExtremeXOS.5520-24W-VOSS:1>enable
5520-24W-VOSS:1#software add summit_arm-31.1.0.540.xos
EXOS image validated successfully
Adding EXOS software - /intflash/summit_arm-31.1.0.540.xos
Extraction of /intflash/summit_arm-31.1.0.540.xos to /intflash/release/summit_arm-31.1.0.540.xos successful
5520-24W-VOSS:1#show software
software releases in /intflash/release/
5520.v8.2.5int030 (Primary Release)
Auto Commit : enabled
Commit Timeout : 10 minutes
5520-24W-VOSS:1#software activate summit_arm-31.1.0.540.xos
Executing software activate for version summit_arm-31.1.0.540.xos.
Validated EXOS software
WARNING: The specified image is for the EXOS Network Operating System and the VOSS Network Operating System
is currently running.
If you continue, all data including configurations, logs and debugs will be cleared, except for the license activation
status. EXOS will be installed and VOSS image files will be removed. Do you want to continue (y/n) ?y
The following table defines parameters for the software command.
| Variable | Value |
activate WORD<1-99> |
Specifies the software version to copy to the boot flash file. |
add WORD<1-99> |
Specifies the software version to unpack. |
| -y | Suppresses the confirmation message to automatically overwrite the non-primary image. If you omit this parameter, you must confirm the action to overwrite the non-primary image. |
