Use this procedure to clear the IP multicast route statistics. This resets the IP multicast statistics counters.
When you clear IP multicast route statistics on the Controller node of a DvR domain, the configuration is automatically pushed to the Leaf nodes within the domain.
enable
clear ip mroute stats
Clear the IP multicast route statistics:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#clear ip mroute stats
