View the OSPF area information.
View the OSPF area information:
Switch:1>enable
Switch:1#show ip ospf area
                            OSPF Area - GlobalRouter
AREA_ID         STUB_AREA  NSSA          IMPORT_SUM ACTIVE_IFCNT
192.0.2.11        false      false         true       2
STUB_COST INTRA_AREA_SPF_RUNS  BDR_RTR_CNT ASBDR_RTR_CNT LSA_CNT   LSACK_SUM
0         9                    0           0             6         117671
Variable definitions
The following table defines parameters for the show ip ospf area command.
 Variable  |
 Value  |
 vrf WORD<1-16>  |
 Specifies a VRF by name.  |
 vrfids WORD<0-512>  |
 Specifies a range of VRF IDs.  |
