If you cannot log on by any means, perform the following steps.
Rlogin is only supported on VSP 8600 Series.
Check if you enabled both TACACS+ and RADIUS on the switch:
Switch:1>enable
Switch:1(config)#show tacacs
Global Status:
global enable : false
authentication enabled for : cli
accounting enabled for : none
authorization : disabled
User privilege levels set for command authorization : None
Server:
create :
Prio Status Key Port IP address Timeout Single Source SourceEnabled
Primary NotConn ****** 3 192.0.2.254 30 true 5.5.5.5 true
Backup NotConn ****** 47 198.51.100.1 10 false 0.0.0.0 false
Switch:1>show radius
acct-attribute-value : 193
acct-enable : false
acct-include-cli-commands : false
access-priority-attribute : 192
auth-info-attr-value : 91
command-access-attribute : 194
cli-commands-attribute : 195
cli-cmd-count : 40
cli-profile-enable : false
enable : false
igap-passwd-attr : standard
igap-timeout-log-fsize : 512
maxserver : 10
mcast-addr-attr-value : 90
supported-vendor-ids : 1584, 562, 1916
secure-flag : false
Check if the administrative and operation status of the port is up:
Switch:1#show interface gigabitethernet 1/2
Port Interface
PORT LINK PORT PHYSICAL STATUS
NUM INDEX DESCRIPTION TRAP LOCK MTU ADDRESS ADMIN OPERATE
1/2 257 1000BaseTX true false 1950 00:24:7f:a1:70:61 up up
Port Name
PORT OPERATE OPERATE OPERATE
NUM NAME DESCRIPTION STATUS DUPLEX SPEED VL
AN
1/2 1000BaseTX up full 1000 Ta
gged
Port Config
PORT DIFF-SERV QOS MLT VENDOR
--More-- (q = quit)
Check if the switch has a route configured to the server network:
Switch:1(config)#show ip route
IP Route - GlobalRouter
NH INTER
DST MASK NEXT VRF/ISID COST FACE PROT AGE TYPE PRF
198.51.100.1 255.255.255.255 192.0.2.65 GlobalRouter 1 100 OSPF 0 IB 125
198.51.100.5 255.255.255.255 192.0.2.5 - 1 0 LOC 0 DB 0
198.51.100.13 255.255.255.255 GlobalRouter 10 1000 ISIS 0 IBS 7
198.51.100.200 255.255.255.255 GlobalRouter 10 1000 ISIS 0 IBS 7
4 out of 4 Total Num of Route Entries, 4 Total Num of Dest Networks displayed.
TYPE Legend:
I=Indirect Route, D=Direct Route, A=Alternative Route, B=Best Route, E=Ecmp Rout
e,
U=Unresolved Route, N=Not in HW, F=Replaced by FTN, V=IPVPN Route, S=SPBM Route
PROTOCOL Legend:
v=Inter-VRF route redistributed
Check if the Segmented Management
Instance has a route configured to the server
network:
Switch:1(config)#show mgmt ip route
Mgmt IPv4 Route Information - Table main
DEST/MASK NEXTHOP METRIC INTERFACE TYPE
198.51.100.0/16 198.51.100.1 300 Mgmt-oob1 STATIC
198.51.100.0/23 0.0.0.0 1 Mgmt-oob1 LOCAL
192.0.2.0/8 192.0.2.1 300 Mgmt-oob1 STATIC
3 out of 3 Total Num of mgmt ip route displayed
