Use the following procedure to display IPsec information on an interface.
Display the IPsec status on a VLAN interface.
Switch:1>show ipsec interface vlan 22
VLAN Interface Policy Table
Vlan Interface Policy Name IPsec State Direction
22 AAA Enable both
22 tcp Enable both
22 icmp Enable both
The following table defines parameters for the show ipsec interface command.
Variable |
Value |
gigabitethernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
mgmtethernet mgmt |
Identifies the interface as the management interface. Note:
Exception: only supported on VSP 8600 Series. |
loopback <1–256> |
Specifies the loopback interface. |
vlan <1-4059> |
