This procedure does not apply to VSP 8600 Series.
You can only configure one Management Instance interface as the default topology IP.
enable
configure terminal
mgmt {clip | oob | vlan}
force-topology-ip
The following example configures the Segmented Management Instance VLAN as the default topology IP:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt vlan Switch:1(mgmt:vlan)#force-topology-ip
