Use the following procedure to enable ping to a virtual IP address. The default is enabled.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router vrrp Switch:1(config-vrrp)#ping-virtual-address enable vrf mgmtrouter Switch:1(config)#show ip vrrp vrf mgmtrouter ===================================== VRRP Global Settings - VRF mgmtrouter ===================================== ping-virtual-address : enabled send-trap : enabled
Variable definitions
Use the data in the following table to use the ping-virtual—address enable and show ip vrrp commands.
Variable |
Value |
enable |
Enables ping to a virtual IP address. |
vrf WORD<1–16> |
Specifies the VRF. |
