To operate properly, Fabric Attach (FA) must be configured properly at both the global and interface level on the switch. Use this procedure to verify FA configuration.
enable
show fa
show fa agent
show fa interface
To view FA configuration on all ports, enter:
show fa interface port
To view FA configuration on a specific port, enter:
show fa interface port [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
To view FA configuration on all MLTs, enter:
show fa interface mlt
To view FA configuration on a specific MLT, enter:
show fa interface mlt [<1-512>]
To view FA interface configuration based on the authentication status, enter:
show fa interface [enabled-auth] [disabled-auth]
Verify that FA is configured globally.
Switch:1#show fa
Fabric Attach Configuration
FA Service : enabled
FA Element Type : server
FA Assignment Timeout : 240
FA Discovery Timeout : 240
FA Provision Mode : spbm
Verify FA configuration at the interface (port or MLT) level, on all interfaces.
In the following example output, note that:
FA is enabled on interfaces 2/10, 4/11 and Mlt2.
Both FA and message authentication are disabled on port 4/6.
Both FA and message authentication are enabled on port 4/11.
Switch:1#show fa interface
Fabric Attach Interfaces
INTERFACE SERVER MGMT MGMT MSG AUTH MSG AUTH
STATUS ISID CVID STATUS KEY
Port2/10 enabled 0 0 disabled ****
Port4/6 disabled 0 0 disabled ****
Port4/11 enabled 0 0 enabled ****
Mlt2 enabled 0 0 disabled ****
4 out of 4 Total Num of fabric attach interfaces displayed
Verify FA configuration on a specific port, for example, on port 2/10.
Switch:1#show fa interface port 2/10
1 out of 1 Total Num of fabric attach interfaces displayed
Verify FA configuration on an MLT, for example, on Mlt2.
Switch:1#show fa interface mlt 2
View the FA interfaces that have authentication enabled:
Switch:1#show fa interface enabled-auth
View the FA interfaces that have authentication disabled:
Switch:1#show fa interface disabled-auth
3 out of 3 Total Num of fabric attach interfaces displayed
