Feature |
Product |
Release introduced |
Entity MIB - Physical Table |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
VSP 4450 Series |
VOSS 6.0 |
VSP 4900 Series |
VOSS 8.1 |
VSP 7200 Series |
VOSS 6.0 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VOSS 6.0 |
VSP 8400 Series |
VOSS 6.0 |
VSP 8600 Series |
VSP 8600 6.1 |
XA1400 Series |
VOSS 8.0.50 |
Entity MIB enhancements and integration for the following:
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
VSP 4450 Series |
VOSS 6.1.2 |
VSP 4900 Series |
VOSS 8.1 |
VSP 7200 Series |
VOSS 6.1.2 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VOSS 6.1.2 |
VSP 8400 Series |
VOSS 6.1.2 |
VSP 8600 Series |
VSP 8600 6.1 |
XA1400 Series |
VOSS 8.0.50 |
Entity MIB - Logical Table and includes integration for the following:
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.4 |
VSP 4450 Series |
VOSS 8.4 |
VSP 4900 Series |
VOSS 8.4 |
VSP 7200 Series |
VOSS 8.4 |
VSP 7400 Series |
VOSS 8.4 |
VSP 8200 Series |
VOSS 8.4 |
VSP 8400 Series |
VOSS 8.4 |
VSP 8600 Series |
Not supported |
XA1400 Series |
VOSS 8.4 |
The Entity MIB – Physical Table assists in the discovery of functional components on the switch. The Entity MIB – Physical Table supports a physical interface table that includes information about the chassis, power supply, fan, I/O cards, console, and management port.
Some hardware platforms support removable interface modules while others offer a fixed configuration. The names used for these modules can vary depending on the hardware platform.
The following table identifies the entity index range for the switch components.
Component |
Entity index range |
Chassis |
1 |
Power supply slot |
3 to 8 |
Fan tray and fan slot |
9 to 16 |
I/O slot |
17 to 30 |
SF Slot |
31 to 36 |
I/O card or module |
37 to 50 |
SF Card |
51 to 56 |
Console port |
57 |
Console port 2 |
58 |
Management port |
64 |
Management port 2 |
65 |
Power supply |
68 to 73 |
Fan tray |
74 to 81 |
Fan module |
82 to 105 |
Port |
192 to 1023 |
Pluggable Module and Sensor |
19201 to 102314 |
For more information about Entity MIB – Physical Table, see View Physical Entities.
