Configure the STP mode to configure the spanning tree mode on the device.
Configure the STP mode:
Switch:1(config)# boot config
flags spanning-tree-mode mstp
Warning: Please save the configuration and reboot the switch
for this to take effect.
Warning: Please carefully save your configuration files before
starting configuring the switch in RSTP or MSTP mode.
Use the data in the following table to use the boot config flags spanning-tree-mode command.
Variable |
Value |
rstp|mstp |
Specifies the Spanning Tree modes: Rapid Spanning Tree Protocol (RSTP) or Multiple Spanning Tree Protocol (MSTP). |
