Configure the IP routing protocol stack to determine which routing features the switch can use.
Use the data in the following table to use the Globals tab.
Name |
Description |
Forwarding |
Configures the system for forwarding (routing) or nonforwarding. The default value is forwarding. |
DefaultTTL |
Configures the default time-to-live (TTL) value for a routed packet. TTL indicates the maximum number of seconds elapsed before a packet is discarded. Enter an integer from 1 to 255. The default value of 255 is used if a value is not supplied in the datagram header. |
ReasmTimeout |
Specifies the maximum number of seconds that received fragments are held while they wait for reassembly. The default value is 30 seconds. |
ICMPUnreachableMsgEnable |
Enables the generation of Internet Control Message Protocol (ICMP) network unreachable messages if the destination network is not reachable from this system. These messages help determine if the system is reachable over the network. The default is disabled. Important:
As a best pactice, enable icmp-unreach-msg only if it is absolutely required. If icmp-unreach-msg is enabled and a packet is received for which there is no route in the routing table, CPU utilization can dramatically increase. |
ICMPRedirectMsgEnable |
Enables or disables the system sending ICMP destination redirect messages. |
IcmpEchoBroadcastRequestEnable |
Enables or disables IP ICMP echo broadcast request feature. The default is enabled. |
AlternativeEnable |
Globally enables or disables the Alternative Route feature. If the alternative-route parameter is disabled, all existing alternative routes are removed. After the parameter is enabled, all alternative routes are re-added. The default is enabled. |
RouteDiscoveryEnable |
Enables the ICMP Router Discovery feature. The default is disabled (not selected). Use ICMP Router Discovery to enable hosts attached to multicast or broadcast networks to discover the IP addresses of neighboring routers. |
AllowMoreSpecificNonLocalRouteEnable |
Enables or disables a more-specific nonlocal route. If enabled, the system can enter a more-specific nonlocal route into the routing table. The default is disabled. |
SuperNetEnable |
Enables or disables supernetting. If supernetting is globally enabled, the system can learn routes with a route mask less than 8 bits. Routes with a mask length less than 8 bits cannot have ECMP paths, even if you globally enable the ECMP feature. The default is disabled. |
UdpCheckSumEnable |
Enables or disables the UDP checksum calculation. The default is enable. |
SourceRouteEnable |
Enables or disables IP Source Routing globally. It is disabled by default. |
ARPLifeTime |
Specifies the lifetime of an ARP entry within the system, global to the switch. The default value is 360 minutes. |
EcmpEnable |
Globally enables or disables the Equal Cost Multipath (ECMP) feature. The default is disabled. After ECMP is disabled, the EcmpMaxPath is reset to the default value of 1. |
EcmpMaxPath |
Globally configures the maximum number of ECMP paths. You cannot configure this feature unless ECMP is enabled globally. Different hardware platforms can support a different number of ECMP paths. For more information, see VOSS Release Notes. |
Ecmp1PathList |
Selects a preconfigured ECMP path. |
Ecmp2PathList |
Ecmp3PathList |
Ecmp4PathList |
Ecmp5PathList |
Ecmp6PathList |
Ecmp7PathList |
Ecmp8PathList |
EcmpPathListApply |
Applies changes in the ECMP pathlist configuration, or in the prefix lists configured as the pathlists. |
